I have the unit ready for a test on the back of the boat in the pond.<br /><br />Can anyone tell me what the nominal settings are for the low and high speed jet screws. That is the number of turns out from the seated position?<br /><br />I used Tom Travis' article to set the timing and found it very helpful.<br /><br />The carb butterfly linkage arm was fatigued and broken, probably from overtightening the set screw. With a piece of flattened copper pipe I was able to cut and shape a reasonable facsimile that fit up fine.<br /><br />Are new motor parts available for this model from a source other than OMC? Just asking in case...<br /><br />Thanks for your help guys. I got it fired up and ran it for maybe 10 minutes or so on the pond but it seemed to be reluctant to idle. Well I pulled it out and noticed that it wasn't cooling properly. Pulled the lower end to check out the impeller. Decided a new one was in order and did a compression check as a matter of interest. It seems balanced - roughly +70 psi on both cylinders. Seems low. So has anyone any ideas on rings? Standard stock number is 486277. Know where they can be found?
