Re: Johnson "tilt assist piston"
Rick...take a look at the cable that leads to the top of the assist cylinder. It connects to the lever on the tiller handle with a plastic connector. Make sure its not broke.<br /><br />If it's OK, check the play on the lever. Shouldn't be more than a 1/4" play. It there is, pop off that plastic connector and adjust it to get the required play. Might help.<br /><br />Let us know the outcome.<br /><br />These cylinders can't be re-juiced.
