TheOutboardKid
Thread starter- Joined
- Oct 27, 2019
- 30
1976 Johnson-Javelin 85hp Model: 85ETLR76G
I was out on the lake last weekend and I had a hard time starting the motor. I tried everything, choke, no choke, more throttle, less throttle, pump the primer bulb, etc. It would sputter for a split second and then die. I finally got it to run after causing a traffic buildup at the boat ramp, but it wouldn't run if I lowered the warmup lever. Once I got out and gave it some throttle, it ran great from 2000 RPM all the way to 5500. It is the second time I've had it in the water, and it idled fine the first time I took it out. It also ran fine on muffs. Gas was brand new, carbs rebuilt in 2017 by the previous owner, along with the power pack and coils replaced in 2016. Compression is 110-115 on all 4 in 2017. (according to the previous owner) I haven't done anything to this motor besides lower unit oil.
I'm thinking it's a fuel issue... but I'm not a pro. Any advice would be appreciated. Thanks!
