Johnson V4 Charging System Wiring
bigrinks
Hi,
i have a johnson V4 140bhp two stroke. 1995 model.
I've manually wired it to my yamaha 501 remote one system at a time.
I'd now like to connect the charging system.
I'm thinking i just need to use a single spare piece of wire to connect the yellow wire from the regulator/rectifier at the screw block to the main positive power supply on the engine block?
Can anyone confirm that the yellow wire (2 off) on the regulator block are the charge supply wires?
Would i be correct in assuming these are jsut connected to the main battery positive wire?
I'm so nearly there! everything else working well!
