Johnson V8 vs. V6 lower unit
commonarcwelder
Anyone know if the Johnson V8 gearcase housing will bolt up to my 1996 Evinrude 225? Thanks, Keith
Dhadley
Re: Johnson V8 vs. V6 lower unit
Yes, no problem excepet that it's larger. I'll assume you're after the higher gear ratio. Being larger it will create more drag. You also have to be aware of which V8 case you use especially if you're going to install a nosecone / low water pick up. Some are longer (like the 3.6) and installing a nosecone can move the steering axis far enough forward that the additional side loads can damage the upper mount.
commonarcwelder
Thanks DH. Everything I needed to know!
Dhadley
A lot of the hot rod guys are using the Merc performance cases on the Rudes.
