Kelly Leister
- Joined
- Apr 6, 2015
- 27
rubnrestore.com
Sun damage is hard to repair without replacing. Any thoughts on just replacing them?Thanks the dog house is next and the side panels, not in bad shape just sun faded. Looking for away to clean and brighton them.
First going to try rub and restore, if that doesn't work then I will redo the pieces my self. Will sew some design into it over the winter.Sun damage is hard to repair without replacing. Any thoughts on just replacing them?
SHSU
What resin to you plan to use? Hopefully epoxy and not polyester.Using exterior plywood marine painted and vinyled Using marine Plywood for the decking will be coating it with fiberglass resin
for sealing plywood (esp douglas dir), you really should reinforce the resin with fiberglass to prevent grain checking (checking cracks the cured resin allowing water intrusion to untreated wood.) if you planned on just coating the wood with resin without glass (ill advised), epoxy is going to have the higher probability of surviving; polyester is fragile (weak/brittle) and lower bond strength than epoxy.Why epoxy and not a polyester?
yw! I learned by reading a few publications from the Gougeon Brothers (link).Thanks any good sites on how to fiberglass a boat deck?
