jump starter
sbuchholz
where do i put my jump wire in order to jump my starter to see if its good. I have power from my battery to it and all terminals are clean. The solenoid just clicks when you turn the key. I want to check to see if the starter is good and i cant remember how to jump it with a wire
kenmyfam
Re: jump starter
I would be checking and cleaning all the connections and cables first. Can we have more info on what motor it is.
socketholder
Re: jump starter
You run a wire from the battery side of the solenoid to the small post on the side. make you you connect to the + side, the other one is wired to ground.
I use battery cables to bench test a starter.( Connect to a good battery, ground the black and touch the red to the post on the starter)
I would check for voltage on the supply side of the solenoid first(from battery). you should have 12 volts on the battery side and nothing on the other until you hit the key. then it should read 12 volts as well. If not check the little hot wire in the solenoid for power from key switch> This will get you off on the right foot to find the problem>
