86IROC
Thread starter- Joined
- Apr 5, 2010
- 89
Re: Jumping in feet first with repairs..
No offense taken. If you look at the last pic above..I'm replacing the deck back to the flotation (?) boxes on either side of the bilge well. The deck under those is solid. so if I end up doing the transom, the end of the stringers is already pretty much exposed. I should be good as far as access..."fingers crossed".
No offense, but the transom goes below the deck all the way to the bottom of the hull and all the way across the back of the boat and is usually attached to the stringers. Not sure how you can replace it with out removing at least a portion of the deck.
