76 Lund President ll
Thread starter- Joined
- May 27, 2013
- 22
After reading many posts here about overheating, I decided to test it in a 100 gallon Rubbermaid stock tank. I am glad I did. Everything seemed to work fine on muffs, but not in the tank. I have a 175 hp electric shift leg off the Lund and I know that boat was in the water 3 years ago. This Seaswirl has not been out since 09, and the same guy put the pump together that installed the Chinese transom seal. The OMC parts sites have great parts breakdowns with numbers and prices. I was able to check and all the pump pieces are the same in two stringers I have. So I disassembled the electric shift leg to figure out how it all goes together and the pump looked great and had the OMC logo and part numbers on most of the parts. I took the 4 screws out of the top of the mechanical shift leg still on the boat. I lowered the lower unit off just enough the seperate the shafts and supported it. I then removed the pump and tore it apart, it had a cheep impeller and the aluminum housing was completely worn out. I used the best parts and the softest seals and reassembled the pump. tested again in the stock tank. I have water now, it took about a minute before it showed up at the weep hole that cools the ball gears. :lol:
