just bought broken transom shield. pics
candrive55
looks like the ends of the ears that controll the trim are snapped off.
Can i do anything with this
Don S
Re: just bought broken transom shield. pics
Get your money back.
If you have to adjust the trim out to the next hole back (where they normally run), you will have no support for the cross pin. If you look at your first picture, you can see where the outer holes have been elongated from wear.
Obviously the seller needed to operate his boat in the middle hole, but it broke. then moved the rod to the inside position and found the boat was plowing through the water because of being trimmed to low. So HE had to replace his. Then he sold it to you. Do you want that same problem????
candrive55
Thanks Don.. I talk to the guy he will give me back the money. And said to keep the shield ( Good guy)
So my Question... Could a machine shop fix this.
candrive55
update took it to a good shop today they said they could fix it no problem. 2 hours worth of work. Thanks for your help Don lets hope it turns out ok.
