Re: just got a 54 evrinrude fleetwin 7.5hp help please
Well, without the fuel filter bowl...guess you could put it in a trash can almost full of water, gravity feed some gas into the carb and it should run for a little while...long enough to make sure the water pump is pumping. Make sure the water in the can/barrel covers at least 3/4's of the leg. I always count the nuts/bolts going into a tank to make sure they all come back out...sometimes you have to do a little shaking, inverting, rapping to get a stubborn one out. Sounds like you're pretty close...read the post on adjusting carbs to make sure your baseline high and low speed needle settings are correct, can be frustrating if they are too far off.
