Nitrous SSC
- Joined
- Jul 29, 2007
- 16
I have a 1996 Maxum.
It had a stalling problem when I first took it out on the lake. I used the service manual the previous owner included and reset the idle. Still didn't really fix it. I sea foamed it and it ran much better. Then I tried taking the carbs off and cleaning them.
Well now it does a VERY strang thing. When I go full throttle it gets to 2400rpms and will not go any higher. Its almost like it loads up. If I rev it in neutral alot then go into gear it will go past that 2400 mark.
I set the carb mixture screws as per the manual and found the engine idles/runs best at 1 1/4 to 1 1/2 turns.
I need some idea's. I'm totally new to these boats. Tomorrow I'm going to try a compression check, but it ran fine before up to 5000rpm.
