jasondemitri
Thread starter- Joined
- Aug 25, 2012
- 5
I just inherited a boat w/ a 1995 mercury 115 ELPTO 2 stroke. I dont have a book yet, but need some basic info. There is an oil tank mounted (stock) on the motor where i assume this is the 2 stroke oil...so do need to mix my gas can as well or do i run straight gas and the oil tank does the rest as in "oil injected". I have a mechanical background and 2-stroke knowledge from the mx world, but very little knowledge in the outboard world. any advice is greatly appreciated.
Also, what maintenance should i perform prior to starting the motor? im thinking the following:
oil change
clean spark plugs
check for spark at all 4 cyl
general cleaning of electrical connections (throughout the boat)
all this prior to trying to start the motor. i do know that there is some work it needs, but not sure what. I didnt get all the info on the issue, but i think it has to do with the motor cutting out like it was missing. I have read that this motor runs on 2 cyl when at low rpm's, so im wondering if the other 2 cyl arent kicking on when they are supposed to. Its on a 1972 glasply runabout.
oil change
clean spark plugs
