icy
Thread starter- Joined
- Feb 28, 2007
- 52
just my luck. I bought a 73 135 hp Johnson, and new controls to replace the 72 125 hp that had bad rings.. Now that I have it mounted and hooked up I was looking to have some fun.. But alas, it seems as though THIS motor has low compression (50 lbs) in 1 cyl too.. this one is getting parts.. You can see tiny bits of metal in one of the new plugs so im assuming its rings.. Is it possible that, assuming the bores are within tolerance (not real likely), I can just rering this thing?? or is it definatly going to need a piston? Its getting to be fishing season here in iowa, and if i cant get this thing together on the cheap, it may have to wait till late fall before I can do anything with it.. which would be a bummer. I have the manual for it, but im just wondering if the powerhead has to come off "if" the bores are good.. its the top right cyl looking from the back.
