Just out of curiosity/spin on flywheel
baja32
Does anyone know if the flywheel on a 1980 150 hp black max spins clockwise or counter clockwise?
emckelvy
Re: Just out of curiosity/spin on flywheel
Are you referring to the direction of rotation of the crankshaft, or which way the flywheel nut goes on/off?
The crankshaft rotates CW as viewed from the top (as does any 2-stroke Merc I know of, barring the Direct Reversing motors which can run backwards for Reverse).
The flywheel nut has right-hand threads and is turned CCW for removal.
HTH, if that's not what you're looking for, pls repost with clarification...........ed
