Just purchase 2nd hand Baylier 175 w/ mercruiser 3L
kidafa
Hi All,
Last week I purchased my second boat! Coming from a 13ft dinghy and a Seadoo Jetski I decided to get a 2006 175 Bayliner Bow rider with a 3.0L mercuiser stern drive alpha one leg.
This is what I plan do before I take it out can someone please confirm/let me know if I've missed anything and give me many advice.
Change/Replace:
  • Spark Plugs and gapp .9mm
  • Oil (25w-40 Marine 4cyl)
  • Oil Filter
  • Drive Oil
  • Fuel/Water seperator
Lubricate:
  • Steering Arm
  • Prop Shaft
  • Shif Cable and Linkages
  • Throttle Cable
  • Enigne Coupler/U-joint shaft Grease Nipple
Clean:
  • Flame Arrestor
  • Internal Fuel Screen Filter on Carby
Check:
  • 6mm Alternator belt deflection
  • Anodes
  • Spray leg and engine with Inox/rust preventive
  • Engine mounts to 52nm
  • Bimbal ring clamp screws to 70nm
  • Cooling lines and hose clamps
  • Battery fluid and charge
  • Trim Oil level
Today I pulled the plugs to see how its been running and they were very black and dry.... Just gave them a clean and re-gapped them all to .9mm and when I re-installed them I got two of the coils mixed up so it wouldn't start tried cranking it a few times and it just backfired ect..... Then swapped the two leads I wasnt 100% sure about and it started and purred away :) Could have I caused any damage while doing this?
Also the propeller has 3 holes in it and one of them has been siliconed up.... See the photos. Why is this? Should I remove it or leave it? Why would someone do this? There is evidence of silicone in the other 2 holes but they are not blocked like one of them.
John_S
Re: Just purchase 2nd hand Baylier 175 w/ mercruiser 3L
Congrads on new boat. No, you didn't hurt anything have two wires crossed for a few minutes. As far as the silicone, looks like they tried to block the ventalation holes. I don't own that type prop, so don't know what the plugs look like. Someone else will chime in on that. Also, looks like the prop is not tight. The locking ring is off kilter with the nut.
kidafa
Off Kilter? ???
Reming870
The prop nut is not resting in the lockwasher properly so it has the potential to slip.
I have no idea why the hole is siliconed closed.
kidafa
Ok. Well Im yet to pull the prop to lube the shaft so Ill check it out then :)
Can I just use marine grease for that? Any special tools required? Can I re-use the lockwasher?
Also how can I tell what carb it has on it? If its an emissions carb or not ect?
ziggy
i just use waterproof grease on my prop shaft. i've never had any problems removing my prop after one seasons use. no special tools required, yes, reuse the lock washer/lock tab.
don't know about the carb. go look at the adults only sticky thread at the top of the i/o fourm. then look at the mercures info section. you'll find a link to some s/m's there. chose your rig and you'll have what ya need to service you rig. while your there check out the winterization and summerization thread. if ya go through those threads, you'll see many preventative maint. items to check. looks like ya have a good handle on what to do, but there may be further info that ya might be able use.
tejastoolman
nice boat no wood floors! =)
John_S
Not sure what you mean by emissions carb. Given the year, you might have a Turn Key Start (TKS) carb, which is a Merc's answer to not pumping the throttle for cold starts. There hasn't been a high speed mixture adjustment for many years, and even idle mixture may be blocked "plug over" on that carb.
kidafa
Retorque the gimbal ring clamping screws to 55 ft lb. Two bolts that clamp the gimbal ring to the upper swivel shaft on the outdrive. #21 here: http://www.mercruiserparts.com/Show...&bnbr=40&bdesc=GIMBAL+RING+AND+STEERING+LEVER should be part of annual maintenance, and I'll bet it has never been done.
Thanks mate thats the exact sort of answers/responses Im looking for :)
Cheers mate :)
Yeah it is a Turn Key Start Model.... Does this mean that theirs no Carby adjustments apart from the Idle speed screw? Thats all I can find on it anyway...
John_S
"Yeah it is a Turn Key Start Model.... Does this mean that theirs no Carby adjustments apart from the Idle speed screw? Thats all I can find on it anyway... "
I believe so, but didn't have the tks service manual at my fingertips on my HD, to confirm.
fastempo
Better check the outdrive waterpump impeller
fastempo
Drain the out-drive gear oil, and then un-bolt the lower portion from upper, i.e. separate the the two portions of the out-drive, (5 bolts,
plus one hidden under trim tab- 5/16" allen type), make sure throttle is in forward position, with prop. to stop clockwise. Impeller pump
body is at top of lower unit. Remove housing, (4screws/bolts). Inspect impeller, should be plyable, but firm. When reassembling, make
sure shift lever and shift shoe are aligned, and pointing forward when in forward gear. Shift lever at top of lower portion and shoe in
bottom of upper portion, and they are mated when you re-assemble the two out-drive halves. Good luck!
kidafa
Ok thanks for the advice fastempo, So I put the lever into well into forward gear before I start any disassembly? I've done a fair bit of on-line reading and watched a few youtube diy's on changing the impeller and it seems pretty straight forward.
Went to my local mercruiser dealer today and picked up all the bits I needed to do the work I stated and the technician sold me the impeller one gasket and a small seal, he said that's all I will need as long as the boat isn't thrashed ect....
Can someone please fill me in on where the small Orange seal goes in the picture that I have attached. It has a small indentation on either end of it :)
Cheers,
Chris
paultjohnson
Ditto on just replaceing the impeller, its a maintenance item, and they are cheap. If your gonna go to all the troublre of disassemble, you should just replace it. An impeller can look fine but be stiffer then it should be...again, just replace it. I would do bit a little differently then Fasttempo suggest. What he said would work, But if I were you I would pull the whole drive of in one piece, upper and lower together. That way you can inspect and lube the engine coupler splines, u joints, look for water intrusion or gear oil intrusion into the u joint bellows and shift linkage areas, lube that as well. I think its alot easier to reassemble the drive when its off the boat . Have someone help you or make a little makeshift stand to hold the lower half. Then lower the upper half back on to the lower to reassemble. Its easier then trying to lift the lower into place, when the upper half is still in the boat. Read up on steps for doing it. Don't forget the quad ring, its that little ring in your kit there. You will need a new bell-housing gasket, cost about $7.00 at the minimum..... Yes put shifter in full fwd position. That puts the shift shaft on the drive straight fwd so it comes apart properly , Get down and look at the little brass foot that comes out of the lower front of the drive, you will see what I mean.
kidafa
Yes I purchased a new impeller today :) Where does the little ring go?
Ill do it with the upper half on the boat im thinking.
Looks like when I install the impeller I have to make the fins all go one direction which way do I make them go or does it not matter?
paultjohnson
Ok...the little ring [quad ring]goes between the upper and lower. There is a little hole on the starboard side , a little bit forward of center, Its where the gear oil travels from between the halves.
I believe when ya put the new impallar in. you will be twisting it in a clockwise , downward motion, lube it with soapy water if ya want.. Just pay attention to the way the old one is installed.. Another step that is highly recommended, is to pressure check your drive... especially after you tear it apart,are you familiar with this ?
