Re: "Just won't Go" Lower Unit Install 140 Johnson
Daviet has it right. Make sure your shift rod is facing forward. I also make sure I lube the exhause plate so it slides up in there easier. Personally, I tilt up my motor ALL THE WAY UP, shift my control unit in forward, then slowly rotate the prop while pushing up from the bottom. You will feel the drive shaft align with the motor and go right in.
