Captain Caveman
- Joined
- Mar 1, 2005
- 1,028
As to not hijack any old threads, I am starting a new one to help others.
I have a 2007 single-axle Karavan trailer with no brakes. Per the owner's manual there are three possible bearing scenarios:
1) 1-1/16" hub, 5-1/2" flange, with 1-1/16" bearings and races on the inside and outside
2) 1-3/8" / 1-1/16" hub, 5-bolt UHI, 10" brake drums
3) 1-3/4" / 1-1/4" hub, 6-bolt UHI, 12" brake drums
Seeing that my axle has a sticker that says "non-brake with springs" and I definitely do not have brakes, I assumed that I would have the setup in #1 above. When I popped out the bearings and races, the inner and outer were definitely different sizes. It was a 1-1/16" on the outside and 1-3/8" on the inside even though I don't have brakes. The manufacturer's part number for the Inner Race is L-168110. This was confirmed when I called Karavan. However, the 1-3/8" bearing race is a hair smaller than the 1-3/8" bearing and is too small to fit snug in the hub.
Therefore, if you run into this problem when replacing bearings in a Karavan trailer where the new bearing race appears 1/16" too small, then you need to buy the L-68111 bearing kit. It has the slightly bigger 1-3/8" bearing races.
It took me four days and seven visits to various boat and auto part shops to figure this out! Now you've been saved.
