Chris Hays
Thread starter- Joined
- Aug 14, 2007
- 87
I aquired a boat which im re-decking, rebuilding the lower unit and firstly fixing up the trailer as it is in a sorry state. I removed the boat from the trailer in the driveway and started to inspect the trailer for what has to be done. I need to replace all of the bunk board brackets (which are made of 3"x3/8" flat bar, bent to a 90 at the top where it bolts to the bunks and welded to the crossmember) and the keel roller brackets and rollers. Nothing on this trailer is adjustable as i think it was made for this boat,(which is why my fabricating and measuring skills are being tested!)The rollers that were on it had long rotted off and i cant even see where the holes are in the brackets where the roller rod used to go. After cutting the old ones off with a torch and welding on some 2"x 1/4" flat to the crossmember i thought, how do i know how high the rollers should be above the crossmember? I bought 12" wide black, i think self centering (small od in the middle and larger od at the ends?) rollers and i have 2 inches of space to play with before i drill my holes for the rod. Should they just stick just above the crossmember to stop the keel from hitting or do i have to put the boat back on the trailer (in the drive) and then mark up where i need them, if so where would i need them? I have a 17' Glastron Sierra 175 I/O and it has 4 bunks on the trailer which i guess will take the weight. If these are the self centering rollers, then wouldn't i need them to touch the keel at all times to guide the unit onto the trailer? HELP!!!
