Keeping storage lockers dry
theoldwizard1
I have a 17' Starcraft outboard with 2 small storage lockers on either side of the splashwell. One is for the battery and a few other small items, while the other is general storage (ropes, spare prop, prop wrench, etc). These lockers are lined with the same marine carpet as the sole of the boat. Ever since day #1, it has been nearly impossible to get these lockers to dry out. The boat is a trailer queen and sit under a cover all summer, with both hatches at least partially opened. 6 months of the year it is stored in a garage.
I am seriously thinking of removing the carpeting from those storage compartments so that the (I assume) wood doesn't rot. Any other suggestions ?
Home Cookin'
Re: Keeping storage lockers dry
Remove the carpet from the bottoms of the lockers, and while you're at it, from the rest of the boat.
For the lockers, especially the "equipment" one, you can always put a square of loose carpet, or a door mat, or whatever if the stuff bounces and scares fish--but take it out.
Anything that can trap moisture will, and that is always bad. it's especially bad when that trapped moisture is further trapped under the main boat cover.
agallant80
Remove the carpet and put plastic crates in there. That way if water does get in there (wet dock line) its not affecting the deck.
Texasmark
First, the cover needs to be canvas. Canvas breathes and allows moisture trapped under the canopy to excape. Most plastic tarps can't vent and some even come with vent panels to help them breathe. Hogwash; get a canvas tarp....canvas is a moisture treated cotton fabric.
Second a compartment exposed to changes in temperature in a humid environment, be it external or internally induced, will get damp. It's a physical phenomenon. So, as stated, remove any thing that will absorb and hold moisture. Most marine carpets are plastic and do not absorb moisture; may make it hard to evaporate, but do not absorb it. Open your hatches under your canvas tarp. Not disagreeing with the other suggestions offered. Just do what works for you. The big thing is getting a tarp that will breathe.
Mark
