key sticking
rosser1
my key is sticking and making motor turn over while off and when trying to crank. it turns over while i try to crank and sometime stick when i turn it off. in order to get it to stop i have to turn key a time or two and when back in off position it stops. what is causing all of my troubles. just started this after on the lake yesterday, and alot of trying to get mariner 90hp inline to crank and run.
rosser1
Re: key sticking
ok but why in 30min did it go bad. did i burn it up by trying to crank it with a low battery
daveswaves
Ensign
Re: key sticking
It did not go bad in 30 minutes, your motor is a 1979, it took 30 years. Replace the switch.
Silvertip
Honorary Supreme Mariner
Re: key sticking
Why does a person get a headache when you didn't have one 30 minutes ago. Stuff happens!!!!!!!!!!!!!
rosser1
Re: key sticking
yeah your right **it happens! more when your messing with a boat and motor that hasn't been i water in a few years.
any ideas what i can do to get key switch out of cranking mode. i have wiggled an twisted and pushed in and out and everything but set it on fire. and i hate to but may have to but new switch.
rosser1
Re: key sticking
some times you go in to a s*it patch and come out smelling like roses. well my problem had nothing to do with key switch, it wasthe starter solinode was stuck closed from low voltage cranking. so that problem is fixed, now to the next one....
