skilet
Thread starter- Joined
- Jan 29, 2009
- 20
Not sure why my paragraph breaks are not showing... But sorry about the tough read. My current boat project is the replacement and relocation of the original ignition switch from the Mercontrol box to the dash of the old Ranger 1776 Super-A with a '77 mercury 1150.
Picked up a Seadog 3 position key switch with push to choke (420382-1) as a replacement, and extended the harness to reach the dash ignition switch location. The tach was not wired up before, and I'll leave it that way, as well as ignoring the choke button on the control box in favor of the push to choke key switch.
I used the original Merc wire colors to extend the harness, and I've run a yellow wire off each side of the neutral start switch in the mercontrol, one of which is connected to a ground terminal bar at the dash, and the other will be to the key switch.
Question is...
The new key switch labels do not match the old one.
I have connected the gray wire to C (choke), but am unsure on which old merc wire colors go to S (solenoid), I (ignition), M (magneto), and B (battery). I am assuming that the other "M" (mag. Ground) terminal can just go to the dash ground bar.
I hope I've explained my question clearly, and appreciate the read, and any advice or thoughts on this.
Question is...
