gotmeaboat
- Joined
- Feb 12, 2010
- 23
i have a 1994 Johnson 150 that uses the oil pump to mix the oil and gas. can i tap into the boats fuel line to run my 4 stroke kicker?
thanks
thanks
thanks
If the fuel tank is straight gas then yes you can run your 4-stroke of the same tank. The oil mixing system in your 150 mixes the oil inside the powerhead and not in the fuel line.
Each motor should have it's own fuel line.
