SkaterRace
Master Chief Petty Officer
Thread starter- Joined
- Mar 20, 2016
- 842
Ended up going to talk to my marine mechanic and he said almost never works on a CC and doesn't know how he would install one so would have to bill me to research. I found some brackets that I am going to run by him and we are going to run it as a pull start, and hook up a steering link to the main engine. Will have to sort out controls as we are planning to use a tiller motor. The idea is set a single trolling speed and steer from the helm.
Going with a 6 gallon fuel tank that will replace the livewell (more so go inside it inside another sealed layer). That will be the second fuel source if we can get it to work and if we can not then going to run a hose to the main tank and just run a shut off valve to make it work.
I was thinking I might do some of the work myself but am starting to rethink that with how easy it would be to screw up the transom and fuel lines.
