Re: Kicker Trolling motor size recommendation
If I were you I would not consider anything less than 15 hp.
I have a 21 foot Aluminum boat 2800 pounds dry with a 15 HP Johnson 2 stroke.
Yes in the river or a small lake it is fine for trolling.
However in the Pacific Ocean with 9 foot swells every 6 seconds and 35 knot winds it will hardly turn up into the wind and swells.
Top speed about 5 MPH on a calm lake.
It also must be a long shaft is you use in the ocean of large lakes at all.
You will want large 4 blade low pitch prop ind the 5 to 7 range.
My prop is 10 inches by 7 pitch by 4 Blade.
I am in the process of up grading from a 15 2 stroke to a 15 4 stroke.
