Remove the lanyard for the normal contacts.Scott I think you reversed the function of the NOHC and NCHO in the explanation of the function or do I think backwards?.
NOHC normally open when lanyard is in and closes when pulling the lanyard.
NCHO normally closed when lanyard is in and opens when pulling the lanyard.
Function should be as I described in my post above.
When pulling the lanyard the switch should close and ground out the ignition.
