I just bought a used boat and motor. 35 H.P. Johnson, 1991 model, has no kill switch on it to connect a tether to in case I fall out of the boat, I want the motor to shut off. Is it easy to install a kill switch onto the ignition switch somehow?
Remove the lanyard for the normal contacts.Scott I think you reversed the function of the NOHC and NCHO in the explanation of the function or do I think backwards?.
NOHC normally open when lanyard is in and closes when pulling the lanyard.
NCHO normally closed when lanyard is in and opens when pulling the lanyard.
Function should be as I described in my post above.
When pulling the lanyard the switch should close and ground out the ignition.
