Kill switch removal
Kenhackett35
I HAVE A ETC 225HO. ON A KENNER CENTER CONSOLE. I WOULD LIKE TO GET RID OF THE KILL SWITCH IN THE IGNITION. WHAT WIRES DO I JUMP.
alldodge
Not an OB expert but the ETC I believe is a 2 stroke
If it is, then the kill switch grounds the Black/Yellow wire to the Black wire
wired like this
Kill switches only have 2 wires. You have more. OEM Johnson OB ign switches will accept a kill lanyard, but will also work fine without one. On those, when the lanyard is pulled, the ign switch is physically turned CCW to the off position.
I cannot see if that is what you have, but it looks similar.
