Kill switch wiring!
Dotong
Hi,
does anyone know how to wire a kill switch? i have a mid 80s classic fifty manual start. the kill switch is there but isnt wired. there are some loose wires 3 or 4 nearby ive tried connecting different ones together but it wont cut out. im using the choke to kill it. even a photo of the wiring would help me!
Thanks
verado7
Re: Kill switch wiring!
from the terminal on the switchbox marked yellow/black run a wire to one side of switch then a wire from other side of switch to a good ground - ( ground shuts off the motor ) if you applied a voltage wire to that terminal on the pack you could kill the pack .
