bang4dabuck
- Joined
- May 24, 2009
- 296
I had a Merc and it didn't have a kill switch. I am replacing it with an 1987 EV 90HP. This came with a control box but I'm switching to a Morse MT-3 control that will be independent of ignition switch. I am redoing an older Whaler. Anyways this motor seems kind of jury rigged. If you check the schematic of the control box mine differs with the kill switch and the horn being directly connected to harness and then to ignition switch. This is not a lanyard type kill switch but a button. The problem I have been having is kill switch is always on. Funny because last week I was having the opposite problem, couldn't shut down engine i.e. no kill switch. I just put in a new OMC ignition switch today but still no go. Could it be the kill switch ? I tested and would lose continuity if I held kill switch button down. Should I bypass the kill switch, in other words just rely on the key switch to turn off ? Should I bypass, see if that was the problem then replace it ? If so with what ?
