killing my battery
loco boater
I have a 2000 Sea Ray EC215 with a 5.0 mercruiser and a alpha 1 genII outdrive. After a weekend of boating and its time to store her for the week I go through my check list including placing the battery switch to off. The only thing I see still drawing amps is my stereo memory and clock. I have two batteries, one for starting and the other for accessories when the battery switch is on. After a week the acc. battery is drawn down. This past month of no use, the battery is completelly drained. The battery is only a year old. Any ideas on where and how to check what else is drawing juice?
rbh
Re: killing my battery
do you also have an amp?
could it still be energized?
loco boater
yes there is an amp, slipped my mind. That could be it. Thanks
Solittle
For what it is worth I disconnect the cables from both of my bateries as part of my normal after run clean-up. I never have to worry about some small drain somewhere that the meters don't detect.
Home Cookin'
Maybe the battery switch isn't wired correctly? turning it off should obviate disconnecting the batteries (talking about a big red battery switch)
Also your bilge pump should be wired directly to battery and not turned off by the switch--possible electrical leak there?
CharlieB
With the exception of the bilge pump, EVERYTHING should be connected AFTER the battery switch. Period
In the real world, people like their radios to remember their pre-set station selections, thus the radio often has a CONSTANT 12 V source direct to the battery. This is the line that often begins to kill batteries.
Boss Hawg
Excellent point- I have about the same setup as you.
(radio memory) except no battery switch so i installed a on board charger with a timer on my boat.
It comes on 1hr every night to keep the batteries maintained :cool:
