Kodiak Anchor - Made by SouthCoast Marine . . .???
tpenfield
A bit of a fail today getting the anchor re-installed.
It fit nicely, but . . . the backsplice was too fat for the windlass, so it would not get to the chain part when reeling it in.
The OEM rode had a stainless steel crimp instead of the splice, but I'm not sure I can do the same. I brought the whole thing back to the house and will see if I can do a better job of splicing it.
I'm wide open for suggestions . . . on getting a better splice.
flashback
Taper the splice tails might be the answer. You would loose some strength but it might be acceptable..
tpenfield
Yup, my rode is the 3-strand twisted . . . I tend to do better with braided or 8 plait.
I used the tail end of the rode which is basically like new, since the rode has not been let out that far. I also tapered the strands and made sure to pull things tight as I went. Hopefully this re-make will suffice. Re-installing (again) is tomorrow's project. :p
tpenfield
All set . . .
The rode does need some tension on it for it to make the transition from line to chain, but it should be fine. In doing a few test anchorings, I noticed that the bow roller had more sharp edges and was abrading the rode. So I did a bit more filing and sanding of the sharp edges. It should be all set.
Overall, I'm not a fan of this windlass set-up. It doesn't work very well.
