elkhunter338
- Joined
- Jun 27, 2009
- 818
Installed 4 Kodiak oil lube hub kits. Seals leaked oil in 100 miles. Fortunately I had wheel bearing grease, grease gun, and my axles where center drilled for grease fittings.
So I pumped the wheel bearing full of grease and was back on the road.
I do not believe I damaged the seals during installation, not sure how I would have done things different.
I cannot see any way the hubs vent pressure as you change elevation and the hubs change temp. Hubs ran maybe 10-20 degs above air temp.
Any one else have this problem or know of a solution.
