L6 Mercruiser simplified engine wiring
ttownthomas
So you have one wire ALT?
Post pic
OK, 1 wire, then your good and don't need the others
ttownthomas
Should the wire from the ALT to the battery be orange? Are the shift interrupt wires ok black or should they be a different color? Do I need any purple/red wires?
ALT wire only needs to be orange if you want to keep the colors correct. Red is fine
The shift interrupt are black. When shifting the switch grounds the - side of the coil to cause a mis fire
Don't know your luck with one wires, but I bought a 100 amp one and used it half a season, then removed. It still sitting on the shelf from boiling my bats
ttownthomas
Well, its what came with the boat. Ill guess Ill keep an eye on them
