Texasmark
- Joined
- Dec 20, 2005
- 15,014
This is a separate thread as I am addressing the engine design, not the shifter as in the Dock Buster thread........and I'm specifically looking for Laddies comments.
Laddies, sir............
Having stated that you worked on 1000's of the 40 cu in 4 cyls, I guess you also had your fill of sixes as well.
Curious as to how Merc designed the engine to reverse using the dock buster F-R scheme.
1. How did the cranking mechanism turn the engine in two directions? I can see turning the voltage around to turn the starter motor in the opposite direction, but the bendix wouldn't work. How'd they do that?
2. I know that engines have spark advance so when you reverse the direction of rotation what did they do with the spark advance cause advance cw is retard ccw.
Thanks,
I'm sure that there are others out there that share this curiousity.
Mark
Thanks,
Mark
