johnny be good
Thread starter- Joined
- May 16, 2010
- 48
Hello all again, demo went great on my transom repair after cutting inner shell with an 3" air cut-off tool [works great] if you use a fan its not bad at all mask and coveralls are a must. Anyway after reading all the answers to my old post I am going with poly resin and exterior glue plywood. I will first preseal the plywood with resin only but my question is when I laminate the first layer of ply to the outer shell do I use mating in between and when I laminate the second sheet of ply to the first sheet do I use mattihg there also or do I just use the matting after both sheet are in place to cover it all and tie into the rest of the boat? Will those cheap foam paint rollers work to spread the resin or will they melt? If anyone is interested in progress pics. they are in my old post titled "plwood help needed quickly" Thanks for all the help I wouldn't have even started this project without this site full of info.
