maineiac5586
Master Chief Petty Officer
- Joined
- Feb 14, 2009
- 828
My 87 55 hp flywheel sheared a key and was a pita to remove the flywheel. I'm lapping in my replacement flywheel and wanted opinions on this pattern. I just set the flywheel on the crank but didn't put the nut on. You can see in the flywheel bore where the valve grind compound ends. Also on the crank snout. Thank you
