Re: laptop gps system
Hows the new boat doing? I remember you posting a query a while ago regarding twin engine problems and motoring in circles.<br />
<br /><br />From time to time the laptop GPS question has popped up here, but not often. You may want to search this forum. Usually when I think of GPS I think of chartplotting as well. I presume that is where you are headed?!?<br /><br />Nobeltecs Visual Navigation Suit is still the top dog for laptop navigation applications. It has received the NMEA (Natl Marine Electronics Asso) award for best navigational software for the last 3-years in a row. It also has a top dog price tag. Also worth looking at is Fugawi, and Transas NaviGator Pro +. Im sure others will post other s/w solutions. Note: dont know why it is but whenever talking about software, everything is now a solution
as if you had a problem.<br />
<br /><br />C-Map is making a small card reader that plugs into a computers USB port to enable the use of C-Map charts for planning. Its called PC-Planner. It does not interface with GPS input, intended for planning a route at home, but then your plan can be interfaced with GPS on the boat. Never used it, only read about it.<br /><br />In general, laptop marine electronics tends to be the apex for navigation applications, radar, sounding, GPS, etc. Using a marine-grade laptop is going to important, as Ralph mentions, especially if you are on the boat frequently. There are a few out there, about $1k more than a normal laptop the last I looked.<br /><br />If you get a laptop GPS application, please post back here and let us know you decided on and why it worked for your application.<br /><br />Good luck!<br />
