Larson 220 Cabrio Water Gets in Cabin. Know why? Where is the Pump that should Drain?
Status
Not open for further replies.
Ken_Sorensen
I have a 2001 Larson 220 Cabrio. We have had this problem since we bought it new. Gets 6" of water in Bottom Well where you step into the cabin. I have never been able to get any diagrams or manual about the "Larson" part of the boat. Any Idea's would be most appreciatted.
MattJudgie
Re: Larson 220 Cabrio Water Gets in Cabin. Know why? Where is the Pump that should Dr
Hi, I have a larson 1999 cabrio 290. I recently experienced water in the cabin as a result of a leak in the fresh water tank. The pump to drain it is your forward bilge and the pump in my boat is under the bed that goes under the upper deck. The problem of these is that the bilge isn't automatic with a float hence the water overflowing into the cabin.
Not sure if its the same for you but hope it helps.
Marko Mancini
Hi Ken - I have just bought a 2002 Cabrio 220 with the same problem, standing water in step into cabin and forward bilge not working. Did you have any luck in locating and replacing your forward bilge.. Your response is very appreciated!!
Status
