Larson with Leak into Bilge
Old Yeller Boater
Reposting this from the mercruiser I/O section:
I've posted some other threads with fixes that are needed to my new-to-me Larson. To recap, it appears I have a blown head on my 3.7 merc. I've also got a leak into the bilge that is a fairly good flow even when the boat is just sitting in the water. It's more of a flow when wakes are hitting the back of the boat during the day and over night, when the water is calm, there's not much water being taken on at all. I'm sure the gap, whatever it is, is very close to the water line.
So...I've taken the boat to a local shop to review the problems. First off, I'm NOT very comfortable with them at this point. They've had the boat a week and called me yesterday to tell me the mechanic had the boat running for over half and hour and it was not overheating. He said they are not thinking the head is blown. They mentioned that the oil is not contaminated and it appears to be fine. I asked them if they water tested it under stress and also told them again that it's a blow between the exhaust and cooling system and not into the oil. That's based on the fact that the colling reservior is bubbling water out violently when throttled up. I had told them all this in the beginning after what you guys told me here on the forum. His response was "oh, you're right. I have that here in my written notes but we missed that". So after that numb-skull testing, I'm beginning to have my doubts.
Now on to the question. While they have it there they also told me they were able to fill the bilge area with water and can see it leaking out the back. no need to put it in the water for that part. (my initial reaction to that after the above conversation was "no duh") They asked their body guy to take a look and he said he believes the fiberglass sounds hollow. They think the leak may be related to that wrather than gimbal housing or something like that. I've set up a meeting with the mechanic and the body guy for 10 AM on Saturday so we can discuss the problems and determine a course of action.
What info could you guys give me to be prepared to talk with these guys on Saturday. I'm a shade tree mechanic. Never torn an engine down and rebuilt, but certainly handy with gaskets, etc. I'm seriously considering just taking the boat back from them and doing the head myself and then work on the leak later. But for Saturday....what should I look out for?
Anyone with a guess as to what it might cost to have the transom rebuilt by a professional? I know there was another member who was doing it themselves. Maybe I can hire them.
I'm guessing they would not know about a bellows problem until they removed things, right? I think what they are after is if I want to pay the cost of all that work....if the boat is worth it to me. They are holding off on any head work until I can decide on the bigger picture. it would be a bit easier to work on the motor while out, so it would be a plus for them, but I know it would have to come out for any transom repairs.
Would a better first step be to remove the outdrive to determine what it's NOT (like bellows), and then remove the motor only when they are more sure it's necessary?
I know there's a lot of what-if's right now. I appreciate your thoughts!
Old Yeller Boater
Re: Larson with Leak into Bilge
Met with the guys at the shop over the weekend. The body/fiberglass guy I talked to was very knowledgable and helpful. Bottom line is he wanted $800 to replace the transom, not counting the cost to pull motor and outdrive. I was a bit surprised with his price, but in a good way.
Having said that, I'm going to get the boat today and going to do the head gasket replacement myself. I'd rather put sweat equity into the boat than paying hourly rates. Over the winter I'll probably pull the motor and have the transom work done.
