stevenj
Thread starter- Joined
- Jun 8, 2008
- 156
On the bell housing assy. where the shift shaft passes up to the shift arm, the exploded views show only a bushing or two and maybe a washer. is this a seal assy. of some sorts? and should it be replaced during maintenance? only asking because on an exploded view of a Gen2 it is listed as an oil seal.
Also at the pivot flats of the bell housing where the hinge pins pass there is
supposed to be a nylon washer where the two flats meet, Yes? if so what would a part number be.
In the adults only section ther is a post on u-joints, would those u-joints be the same for earlier alphas?
And last is the OEM lower shift cable the best or is the sierra aftermarket
just as good.
Thank you all for your patience and help
Steve
just as good.
Steve
