bassboy1
- Joined
- Jun 23, 2006
- 1,884
I have been doing a little work on this late '60s 6 hp Johnson I picked up for a song. Because the motor is missing the ID plate, I only have the serial number to go by. Wbeaton and I have guessed it to be a 1968. If someone has a year list that goes into the 2.75 million serial numbers, I would appreciate if you could find the year for me.
Anyway, like all motors with unknown history, I check to see if there is gear lube, then hook up a fuel tank, and try to start it in a test tank. Once I sorted out the issues in the ignition (Flywheel woodruff key sheared, since flywheel wasn't torqued), I got the motor to run rough. I noticed that it wasn't pumping much water, and a short bit later, wasn't pumping any water. Wasn't real worried, as I figured the impeller was toast, and I wasn't going to kill the engine running it for 20 seconds. So, today, I put on a new impeller, and found the old one in pretty good condition, so it apparently wasn't the reason the thing wasn't spitting water. The sand in the water passages down under the impeller plate may have been the culprit.
Put it back together, and still no water, and it is starting to overheat. Great. Pull it back apart, expecting to find that I missed the water tube, or forgot the woodruff key, but all is well down at the water pump end. For kicks and giggles, I blew compressed air up the water tube, and a little sand popped out the exhaust hole (apparently this thing was run in very shallow water given all the dried sand I pulled out of the impeller housing, and water intake). I am fairly confident that at least by this point, I have gotten all the passages clear. Anyway, I bolt the lower end back on, again making sure I have the water tube lined up, and crank it again. No water again, after at least 15 seconds. So, I shut it off, and throw in the towel for the night.
Obviously, I am just leaving out one little detail, that I will probably kick myself for once y'all remind me of it, but I can't for the life of me figure out what I forgot to do this time. Also, what is the general consensus on how long it takes for water to start coming out of the exhaust ports on the exhaust housing? Obviously, some exits through the underwater exhaust, but eventually it will exit the top port too, and at a very good flow, at least based on my experience with other motors of this design. How long should that take?
Bassboy
Bassboy
