late 70's/80's Johnson 9.9 carb tuning
59Ford
Recently got a Johnson 9.9 outboard, I think it's late 70's to mid 80's, it's all white and has the idle know on the port side and carb tuning knob by the choke.
Anyone know the stock carb settings, if I pull the plastic knob off and turn the screw all the way in, how many turns out is the factory setting. Also is there a low speed needle on the carb too? It runs pretty good but not quite perfect, just want to reset anything the previous owner might have messed with.
Thanks
Vic.S
Re: late 70's/80's Johnson 9.9 carb tuning
Tell us the model number and we will tell you the exact year.
The adjustment you see on the carb is the slow running mixture.
The basic setting is to gently seat and the come out 1.5 turns.
See Joe Reeves' instructions on the Engine FAQs board to properly adjust the mixture screw.
http://forums.iboats.com/showthread.php?t=167352
See Leroys Ramblings on the side bar HERE for practically everything you need to know about the 9.9 hp engines
59Ford
Thanks, I'll check those out.
Model #: 10RL77A
Serial #: E4641801
59Ford
Also what should the plug gap be. It seems like it misses every so often when idling slow and when we had it in the water(on a boat) running WOT every 30 seconds it would cut out for a slit second then keep going like normal.
Vic.S
that model number makes it a 1977 model.
Plugs should be QL77JC4 or QL82C gapped at 0.030"
