late 70's early 80's Evinrude starting and id question
Claytor
Hello,
I just purchased a 25 ph late 70's early 80's Evenrude.
First off I am having a heck of a time finding the true serial number? There does not seem to be a welch plug? There is no exhaust hole in the prop, making it before 84, as I understand it. Any tips on where the serial number may be located?
The linkage between the pull cord and fly wheel is broken. When i opened it up there was what looked like a mangled coat hanger and some broken blue pieces of plastic floating around. Can anyone tell me what this part is called and where to find it.
Thanks,
ClaytoR
Claytor
Re: late 70's early 80's Evinrude starting and id question
If it helps the # on the block behind the spark plugs (just found it hiding) is 326044 D-1
The number on the side of the block is 327637 D2
The number on the bottom of the tiller arm is 326713
Thanks
ClaytoR
tashasdaddy
should be a plate on the transom mount, just above and between the mount bolts. my have grease all over it.
