Late 70s Weeres or dented late 80's Leisure Island?
Winats2
The dent is several feet long along the bottom and may be from someone storing it by putting the pontoon on a concrete block rather than storing it on a flatter surface. Dented pontoon pressure tested and doesn't leak.
Both are 24 foot boats.
Assuming all other nice parts and problems are equally as likely for each boat, is there a reason to choose one of the above over the other?
MH Hawker
Re: Late 70s Weeres or dented late 80's Leisure Island?
I would go with a un damaged toon ever time, ever thing else is a easy fix.
Cubbyblue22
I'd def. go with the un-dented pontoon. Once that aluminum is dented it becomes weaker and cannot be fixed unless replaced.
Winats2
Thanks. Didn't know that. Will do.
