seanderson
- Joined
- Sep 1, 2011
- 4
Long time lurker, first time poster...
So tonight we were out and decided to explore an inlet with the kicker. Started up, and away we went. All seemed normal. Then there was a (relatively fast, but not immediate fast) sound of the engine reeving up and a lost of thrust (there was still some). I immediately throttled down as low as I could, the engine rpms lowered, and we had normal low rpm thrust. Increased the throttle (slowly) rpms increased, thrust increased, as it went on the same thing happened... engine revs up, thrust decreased.
I tried putting the shifter in and out of gear (F to N to F and F to N to R... F) and the problem was still there.
I do have appropriate thrust at low rpms. It's when more throttle is applied does it sound like its slipped out of gear (although it appears there is still some thrust). Also note that when it first happened there was no sound of anything breaking; just a relatively fast (3 seconds) sound of rpms increasing and thrust decreasing. And also... engine sounds normal at low rpms in forward, reverse and neutral.
Thoughts? Ideas? Suggestions?
Huge thanks in advance!
