Late 90's Nissan 70
Reg312
I'm looking at a 24' pontoon that has a late 90's Nissan 70 P.L.U.S oil injected. I've tried to do some research on this motor but have found little info on if this is a good motor. Any advise on overall reliability on this motor if its been taken care of properly would be appreciated.
pvanv
Re: Late 90's Nissan 70
What is your model? Do you have a 70C? if so, it's a solid motor, flawless oil pump system, and both carb kits and wp kits are still available.
TOHATSU GURU
If it is the 3 cylinder model you are golden...If it is the 2 cylinder model you need to runaway.
Reg312
Thanks for the replies and info. Going to check it out this weekend.
