- Joined
- Jul 23, 2011
- 53,252
Re: Launching and loading by yourself?
I launch all the time by myself. 26' total length cuddy.
here is typical based on the two launches I typically use.
load boat at home
pull into marina and park in prep area
pay launch fee
install plug
undo transom straps
disconnect trailer wiring
then pull into ramp area
back down ramp, once boat is in water at right depth, tie boat to dock cleats
disconnect winch and safety chain
gently push boat backwards
hop back on dock, undo lines, and walk boat out farther on dock
tie off boat (use bumpers as needed)
turn on blower
walk back to truck
hop in and park truck/trailer
walk back to boat
lower outdrive
start boat
undo dock lines
back out of ramp area
go boating
total time that ramp lane is tied up is under 5 minutes
retrieval is easy
come into marina
tie off boat at ramp dock
raise outdrive
walk to truck
back trailer into water to correct depth
undo dock lines and walk boat to trailer
center boat, pull out 5' of winch strap
connect to boat
winch onto trailer
connect safety chain
pull boat out of water up ramp
pull plug
install transom straps
connect trailer lights
check trailer lights
hop in truck and drive home
total time under 5 minutes.
if you have any question of boat starting and running, then repair the boat prior to leaving the house
load boat at home
pay launch fee
install plug
undo transom straps
turn on blower
walk back to truck
walk back to boat
lower outdrive
start boat
undo dock lines
go boating
retrieval is easy
come into marina
raise outdrive
walk to truck
connect to boat
winch onto trailer
pull plug
