BuzzStPoint
Thread starter- Joined
- May 27, 2009
- 1,003
Been having issues with my lawn push mower.
Last year it would start fine and normal. 1-2 pulls. I would only run for a minute or two then the RPMs would slowly decrease till it killed. Then it would be 5+ minutes of pulling and repeat. After 2-3 times like that it would run fine.
This year i couldn't even get it started. So I changed plug, cleaned carb, changed bowl gasket, needle and seat. Got it started, but it does the same thing. When I finally get it running to where it will stay, it seems very low on power. Any thick grass will severely bog the engine down.
Any ideas?
Tecomseh engine
LV156XA 331010A
Carburator is a : Tecumseh 640339
Work performed so far this week.
New Plug
Changed oil - Synthentic
Removed and cleaned carb
Needle, seat, bowl gasket replaced.
Sharpened and balanced blade.
Re gapped the pickup to flywheel.
Any ideas?
Tecomseh engine
LV156XA 331010A
New Plug
