Lazy alternator
Lift12
1998 7.4 MPI 0L347054
Alternator doesn't start charging till RPM gets above 2500 but will continue charging at lower revs once it starts. Is it just time for a rebuild or is there something else at play here?
matt167
That means it’s not getting power to the exite wire and needs to exite itself. Check for broken wires.. if the boat is new to you someone might have wired it as a 1 wire alt which works like that
zellerj
Sometimes with winter condensation etc, corrosion limits the alternator's function. Try spraying some WD40 into the unit to polish it up some. Worked for me when I had this issue.
Pull the alternator, put a new regulator in it
Ayuh,..... It should kick in at 'bout 1500 rpms, 'n run continuous after once rev'd,........
